To replace any object, select it and use the Replace option from the context menu. The platform suggests similar objects by default, with an option to browse the full catalog for unrelated replacements. Position and rotation are preserved where applicable, making replacement efficient and non-destructive. This workflow is ideal for experimenting with alternative design elements, such as swapping a window type or changing a sink model. Replace can be used repeatedly to compare design options while maintaining layout consistency.
